The parts are: R1=10k, R2=2.2K, R3=100 C1=47uF/50V, C2=2.2nF, C3=10pF, SW=switch, B=Battery 9V.
The coil L should be closely wound 5 turns (start tunning with the closely wound distance of turns and then play with it and the C4 capacitor, to find the desired frequency )of enameled copper wire 1.5mm and internal coil diameter of 1cm (leads 2x20mm).
The variable capacitor C4 should be air trimmer capacitor rating 4 to 30 pf or the closest to this value.
As for the transistor Q its the 2N3553. Its a RF Power Silicon NPN Transistor in a TO39 type package designed to be used in amplifiers and oscillator applications in military and industrial equipment.
![image.jpg image.jpg](https://makerv2.webteractive.co/forums/data/attachments/18/18625-f1c4747a9785de9efa8e1256c6dd91d6.jpg)
