For a simple RC circuit, connected to an SG and an oscilloscope, what sinusoidal output should I use? If anyone could point me in the right direction it'd be much appreciated!
It should be maximum to prevent loading, right? But in this case don't we want as much voltage across the circuit as possible? Thus a low output impedance on the SG?
HINT - if you use maximum resistance all the signal will drop across it , without reaching the load [in your case the RC circuit] , so think over again
