What kind of switch should I use?
Hello there,
I'm hoping someone might offer some advice as to how I can build this simple circuit. I'm an electronics novice so please bear with me.
I want to be able to mute two mono audio speakers with the flick of a switch (instead of leaning across the desk at work and twiddling a mixer knob down, and then back up again, something I might do hundreds of times a day).
I figure if I interrupt the signal from the amplifier to the two speakers with a switch I could mute the audio. I thought I would place two 1/4 " jack female inputs in a box and have two 1/4 " jack outputs from the box. Then put a switch between the input and outputs on top of the box. But what type of switch should I use? I realise I have two independent signals for each speaker so I need some kind of switch that can turn off two circuits with a flick. Can anyone tell what kind of switch I need?
Many thanks,
Julian
