What is the difference between Flash and PROM?
PROM = program once, read many times. You cannot erase and re-program a PROM.
FLASH = can be programmmed and erased many times.
Different physical mechanisms are used for these.
KrisBlueNZ
Sadly passed away in 2015
EEPROMs and Flash ROMs are both electrically erasable and reprogrammable. The differences are that EEPROMs are normally smaller than Flash ROMs; they are normally accessed serially (which is relatively slow) instead of in parallel like Flash ROMs; and they are erased and reprogrammed using a command-based interface; they may be reprogrammable in smaller chunks.
KrisBlueNZ
I should have said, to summarise, that EEPROM is used for data storage under program control, and Flash ROM is used for code to be executed directly by the MCU.
