Hello,
I have seen many definitions in many articles throughout the Internet... here are some of the definitions I found:
and so on....
But my question is, for example, for a given differential op amp circuit, if we have a CMMR of:
CMRR = Ad./Acm
CMRR = 2/1
Can we say that in this case the CMRR:
"is the ability of rejecting 1 volt of common voltage for every 2 volts of differential voltage"
I am looking for a definition of CMRR that involves a reference to its numbers in its ratio!
Thanks all
CMRR stands for common mode rejection ratio. It is a
measure of the ability of a test instrument to reject
interference that is common to both of its measurement
input terminals. It is expressed in decibels and it is the
ratio of the actual or common signal level appearing on the
two input terminals together to the measured level.
CMRR whichis defined as the ability to reject the common
gain.it is also defined as the ratio between the
differential mode gain to the common mode gain.
The ability of a differential amplifier to not pass (reject) the portion of the signal common to both the + and - inputs.
and so on....
CMRR = Ad./Acm
CMRR = 2/1
Thanks all
