What is right size resistor
Hello
Have 6 volt battery , device call for 3 volts at 350MA .
Could it be a 10 ohms resistor at 25 watt or am I wrong.?
mrel
DC to DC conventer
I am using 6 volts battery on a dc to dc conventer that need 3 volts at 350 MA so am I doing right thing using resister to drop the voltage from 6 volt to 3 volts and 350 MA
Is there better way to drop voltage from 6 volts dc to 3 dc volts at 350 MA?
mrel
No.
One option is to use a DC to DC converter. Another is to use a regulator.
A DC-DC converter is a special case of a switchmode regulator.
What voltage does the DC-DC converter you're powering produce. I hope it's not 6V!
Oh, and 350 mA
Not MA
edit 1 MA = 1,000,000,000 mA and is a current I can't imagine seeing in anything powered by less than a dedicated power station (kinda)
try using potensiometer, connect pin 1 to battery and connect pin 2 to voltmeter/multimeter then adjust the potensiometer to get the right voltage..
Don't use resistors of any kind for voltage reduction unless you know that the converter either: draws a constant current, or: tolerates 6 Volts.
I know converters/inverters doesn't draw anywhere near constant currents. On the contrary they tend to draw a constant power.
If the converter can't stand 6V directly then the only low-tech solution is to use a 3V 1W zener in series with the battery.
