Hello,
I am currently looking into the Datasheet of a SRD-05VDC-SL-C relay (https://www.circuitbasics.com/wp-content/uploads/2015/11/SRD-05VDC-SL-C-Datasheet.pdf) because i want to use it to control an heating element (230V, 1kW).
On the first glance everything looked fine as the relay can handle 7A with 240VAC.
But than I found the parameter Max. Allowable Power Force (240W) and I really don't know what to make of this. Is it the maximum power the relay can switch? If so, isn't the 7A with 240VAC kind of misleading?
greetings and thanks in advance
Braiden
Braiden
