Weller EC2002 display goes out
Joerg
The Weller EC2002 is their solder station with a red 7-segment
display. Problem: After less than a minute the display goes dark
yet the temp remains stable. Seems like the chip in the station
is shot. Did anyone see this before and found a fix?
Regards, Joerg.
John Woodgate
I read in sci.electronics.design that Joerg <notthisjoergsch@removethisp
It could be a problem with the power supply (dried up capacitors). Can
you measure the supply voltage of the display circuit?
Joerg
John, there is a stable 5V on the display and I can't see much telltale
ripple riding on any supply. Diagnosing a lot deeper is a challenge since
the circuitry is made up of two thick film hybrids wedged against each other
back to back. Thick may be a misnomer here as one is so thin that I am
afraid I could break it with a touch. The three 7-seg devices are driven by
one of those direct bond chips under a blob of tar.
Regards, Joerg.
G
Guy Macon
You need to order a EC236 display board, degrees F, 120v
http://www.google.com/search?q=Weller+EC2002+ec236&lr=&filter=0
Joerg
Yes, Guy, that would be the easiest way. They want almost $100 for that little
board. Ouch.
Guess I may have to bite that bullet or dust off an old non-display station, the
ones with just a potmeter and an LED. Somehow they don't die so often which is
probably due to their simplicity.
Regards, Joerg.
John Woodgate
OK, it sounds as though even if you found the fault by some means, it
wouldn't be repairable.
G
Guy Macon
There is always tho old last resort before throwing it away;
reseat any connections you see and reflow any solder joints
you see. This is unlikely to help, but it only takes a couple
of minutes to try.
....Assuming that this isn't your only soldering iron... <grin>
