Ok all, here's what I have already.
22-23 VAC out from the stator, single phase into a plug. The lawnmower has an electric clutch that I need to keep engaged in order to mow a bunch of lawns. I have tried charging the battery and it holds enough charge to keep the clutch engaged for a little while. What I want to do is build my own rectifier circuit, possibly regulate it, in order to charge the 12VDC lawnmower battery and to keep the clutch engaged. I rigged one circuit up already, but the components get REAL hot and I can't heatsink the individual diodes.
Everything I have seen while searching today seems to show that the output from approx 12VAC thru the rectifier, and adding a capacitor across the + and - output lines INCREASES output voltage. How is this???
All in all, I would like to take the approx 23VAC from the stator output (2 wires) and bring it to around 14.5VDC @ maybe 10 amps. I have no idea how many amps the stator can supply though... although I would bet it's enough to charge the battery! Other than the electric clutch and the battery charging, there are no other loads on the VDC side of the circuit.
