Wanted: Simple megaphone-p.a. amplifier schematic
Sal Brisindi
Hi There,
Does anyone have a schematic for a half way simple PA amplifier around
10 watts to run off a 12 volt gel cell. I do have a few PA amps but I
want to make something small to fit inside a speaker box.
I did the usual google search but didn't find anything out there.
Regards,
Sal Brisidi
Ninja
Sal Brisindi said:
Hi There,
Does anyone have a schematic for a half way simple PA amplifier around 10
watts to run off a 12 volt gel cell. I do have a few PA amps but I want to
Regards,
Sal Brisidi
Here's one I found Googling for "10W Audio IC". It has the schematic and
printed circuit board layout too.
http://www.st.com/stonline/products/literature/ds/1469/tda7240a.pdf
Y
Yukio YANO
Sal said:
Hi There,
Regards,
Sal Brisidi
Use an old CB Radio !!!
Yukio YANO
E
Eeyore
Sal said:
Hi There,
Just about any application note for an audio ampliifer chip designed for car use
will give you the power amp section. Use 2 amplifiers in 'bridge mode' to get a
power level of 10W or so.
A suitable microphone pre-amp stage can be made from a single op-amp. There must
be hundreds of examples out there of that online.
Graham
Sal Brisindi
Graham
Thanks all,
I guess I should have mentioned I wanted to use discrete components but
using a IC sure will save the parts count.
Regards,
Sal
E
Eeyore
Sal said:
Thanks all,
I can't think of a single good reason to use discretes for this application.
Graham
Sal Brisindi
Graham
Graham,
You win, ee neither... :)
Thanks,
Sal
