MRW
Hello .... I have an old MAX038 IC. I wanted to build a simple signal
generator. One of the pins in the IC datasheet accepts +/- voltages to
adjust the frequency at the output. I was wondering if anyone can give
me some tips on how I can build a voltage source that has one
adjustable output that can range from -2.5V to +2.5V.
I was originally thinking of using two voltage regulators with
adjustable positive and negative outputs. I could then switch between
the two if I wanted to adjust my frequency up or down from the nominal
value, but I figured it'd be more interesting to build just one circuit
that has one output that goes from negative to positive.
I appreciate schematics, but what I really want is a resource that
explains to me how each part of it works and the concepts behind it.
I'm still learning. Thanks!
