Voltage regulator voltage too high
I’ve bought 1000+ L7805CP voltage regulators - made by STMicroelectronics. On all the data sheets it say there is a +-10% voltage tolerance yet the voltage I’m getting is +55%. It says it’s input voltage range is 35v - 7v and its output is a nominal 5v (4.5-5.5v) yet I’m getting 7.85vdc. My power source is a 28.8v battery. Is this just a faulty batch or am I overlooking something? Thanks
thanks.
bertus
Hello,
Do you have the decoupling capacitors mounted on the regulators?
Without them, the regulator may oscillate and show a to high voltage.
Bertus
Hi Bertus,
I am not using a decoupling capacitor. I have used the same voltage regulators before the only difference being before they were 12v output & not 5v. But I never had to add anything else to the circuit. Could you recommend a decoupling capacitor I could use? Thanks
Hi Chumply, linear regulators like the 78xx series usually require a load in order to regulate correctly.
The datasheet will have this information. Try a 1K resistor as the load to verify whether this is the case.
Also try without the caps. Caps are usually only required if the input voltage is a small distance away. The output caps are usually small ceramics if required at all.
Read the datasheet. It will have sample circuits showing approximate cap values.
Martin
Why not look up the data sheet?
Try a 100nF cap on the output and more on the input.
Thanks Duke37,
I have read the 57 page data sheet - but not being too confident in these matters I thought it best to ask. Thank you very much for your suggestion - I’ll give it a go.
Martin
Thanks Martin,
I’ll definitely try this and let you know how I get on.
If they were really cheap, you might not have what you think you have. I found some cheap lm337's that were not lm337's :-(
