Voltage multiplier
Hello,
i have a small project, where i must reach pulses cca 100V, frequency 10Hz, pulse width 5ms.
My supply battery is 3.7V and i generate pulses with microcontroller.
So, with a small transformer i can achieve 100V pulses, but the transformer is too big ! So i decide, to make a voltage multiplier, but,....have a little problems with this. Any suggestion?
Thks from stari (Slovenia).
What is the current needed at 100V/10Hz ?
Thks for quick answer.
I need this device as TENS - pulses should be 1-50 mA on 1KOhm load. Some machines have higher current, but i think 50 mA is enough.
Also i can control output pulse Voltage, from 1 - 3,7V.
Stari
You can generate the high voltage at high frequency (100kHz) so using a smaller transformer. This would need to charge a capacitor which would be switched to the output.
A rough calculation, possibly wrong, would require a 10μF 100V capacitor to hold 50mJ.
The size of the pulse transformer you are using will depend on how well it is designed for the job.
100V and 50mA can be LETHAL, especially for anyone with a weak heart or pace-maker!! You should take great care when using this.
Most TENS units have a small switching power supply. This can be a non-isolated boost circuit of a fully isolated flyback, but either way there will be magnetics involved and that means some bulk.
Boosting 3.7 V to 100 V is a ratio of 27:1. At 90% efficiency (a very high value), that becomes 30:1, so for a 50 mA output you need 1.5 A of input current. Your duty cycle is only 1:20 and that helps reduce the input current, but this still will be a hungry power converter. Another option is to let the flyback pulse be the output by shaping it with a clipper. Much more efficient, but not a cookbook design.
TENS units are very inexpensive and tested and safe, so why do you want to build one?
ak
ak
AnalogKid, i know, but i have such project to realize for my boss. (??). Ok, no problem, i will try by your suggestion.
In fact, i will make TENS controlled by Android or iOS.
