Voltage loss over diodes/transistors
Jan Nielsen
I have a circuit that runs off a 5VDC regulator.
I need to drive 2 relays, and the ones I have are 6Vdc, but ofcause they
switch fine at lower voltage.
The problem is, to switch the relay I have a transistor, and then a
diode to prevent back current, after the transistor and diode I am left
with 3.8V which is very close to the limit of what the relay will
accept, so its not that reliable.
Is there a way to limit that loss, or do I have to run at a higher
voltage to start with ?
/Jan
Rich Grise
Don't put the diode in series - put it in parallel with the relay coil,
in reverse polarity, of course.
Good Luck!
Rich
I
ian field
Jan Nielsen said:
The problem is, to switch the relay I have a transistor, and then a diode
to prevent back current, after the transistor and diode I am left with
3.8V which is very close to the limit of what the relay will accept, so
Is there a way to limit that loss, or do I have to run at a higher voltage
to start with ?
/Jan
Use an additional 8V reg just for the relay.
Also do what Rich said, the transistor VCEsat should be around 0.2 - 0.4V so
you should have way more than 3.8V left for the relay.
Chuck
Jan said:
/Jan
If you can use an adjustable regulator,
you can sense the 5 volts at the relay,
thus avoiding the voltage drops.
Chuck
E
Eeyore
Jan said:
As has been mentioned, the diode should not be in series with the coil but
reverse parallel.
To keep the transistor voltage loss to a minimum, drive the base with plenty of
current to as to saturate the transistor ( say use a ratio of Ic/Ib of 10:1 )
and select a transistor with a low saturation voltage Vce(sat).
What's the coil resistance btw ?
Graham
Jan Nielsen
Thanks all, I connected the diode across the relay coil legs and it works.
Sounds right with the 0.2-0.4 loss from the transistor, plus the 0.7V
from the diode = 3.8.
I cant run the circuit at much higher voltage, since theres a mcu
accepting at most 5.5V.
But it works with the parallel diode, thanks.
/Jan
John Popelish
What voltage is available up stream of the regulator? Using
that voltage (with an additional series resistor, if needed,
to drop the extra voltage) will keep the regulator output
cleaner and give you a certain activation.
Jan Nielsen
100ohm between the coil legs acording to my DMM.
The base of the transistor is being driven from a mcu, so it can get
atmost 20mA.
/Jan
Jan Nielsen
John Popelish skrev:
What voltage is available up stream of the regulator? Using that
voltage (with an additional series resistor, if needed, to drop the
extra voltage) will keep the regulator output cleaner and give you a
certain activation.
Theres 9-14V or so before the regulator, from a 12V 20Ah battery drawing
7.5A at peak, my circuit is only using about 60mA at peak, and <10mA at
idle, which is most of its time.
/Jan
Jasen
you have the diode in the wrong place, (should be parallel with the
relay in the non-conducting direction)
if you can use the power from before the regulator to run the relay
that would help.
Bye.
Jasen
I
ian field
/Jan
The suggestion seems to be that if you run the relay off a separate supply
path, you reduce the risk of switching transients on the mcu rail - a
dropper resistor from the unreg supply would be fine and if you included a
small electrolytic this would charge to the full supply when the relay is
off giving a brief burst of higher voltage making the relay snap to more
positively, you could also reduce the overall relay current to the minimum
safe holding value without compromising pull-in. With the voltage margins
you stated, my suggestion of a separate 8V regulator would require a LDO
type.
John Popelish
type.
It would also eliminate about a half watt of heat into the 5
volt regulator (move it to the series resistor), possibly
eliminating the need to heat sink it.
E
Eeyore
Now that's useful.
Such measures can help reduce the build-up of hot spots.
Graham
E
Eeyore
Jamie said:
Also, it's good practice to put a bypass diode from the input to the
output of the regulator.
Excellent advice.
many regulators do not like voltages much
higher on the output side than on the input side.
Yes, it can cause latch up.
Graham
Jamie
Jan said:
/Jan
Config your circuit using a common emitter for the transistor.
the collector goes to one side of the coil.
the other side of the coil to your 5 VDC.
the base with a resistor in series goes to your switching signal.
Place a protection diode across the relay coil. , the cathode (line
side) will go to the 5VDC+ of the coil, the anode to the collector side
of the coil..
Coils will release high voltage energy if allowed to discharge at a
rapid rate. Coils discharge in reverse polarity and thus the diode makes
for a component to do the job.
output of the regulator. many regulators do not like voltages much
higher on the output side than on the input side. if you place the
diode with it's cathode to the input and anode on the output. current
will only flow when the output is higher than the input and thus force
caps on the output to discharge. etc..
Jan Nielsen
It would also eliminate about a half watt of heat into the 5 volt
regulator (move it to the series resistor), possibly eliminating the
My regulator dont need heatsink, its a small plastic version, rated at
max 100mA, the relayas draws 50mA each, but wont be on at same time, and
the rest draws a few mA, so it will do :)
I have the bulky 7805 laying around too, that needs to be bolted to the
copper.
/Jan
