i am intent on building a simple heterodyne bat detector based on this one by Bertrik Sikken (http://bertrik.sikken.nl/bat/simphet.htm).
But i am using a 9V battery, instead of the 6V he has. Looking at the circuit, and reading his article, i realised he was biasing the transistor, and that i would have to redesign for 9V. This is new for me so, have i got this right?
deciding on 1mA for the max Ic, and 1k emitter resistor, i get a max voltage drop across the collector of 8V, and therefore Rc=8k, and Qpoint of 4V and 0.5mA. From there, i am looking to get 0.5mA/Beta (500 or so depending on manufacturer for the BC550C) for the base current of the transistor, giving me 1uA. so far so good (i think...).
for R2, the voltage drop must be the drop across Re + Vbe, which gives 1.7V, and the current through it must be AT LEAST 10xthe base current. (if it has to be AT LEAST 10x, can it therefore be lot more? I will come back to this.)
with 10xIb i get R2 = 180k, and R1 = 7.3/(10xIb + Ib) = 691k
I was looking at these values, and thought they were quite high for R1 and R2, then i remembered something about Stability factor, found the equation, and got a value of about 113 - not good. To reduce this, you can increase the value of Re, which in turn reduces the possible voltage swing, or increase the thevenin value for the divider R1 R2, but that increases the current and therefore decreases the life of the battery.
assuming i have got everything right so far, this is my first question: can the current through R1 and R2 be not 10xIb, but 100xIb? Everyone always uses 10x in every example I've looked at. Doing the calculations again, but with 100xIb instead of 10x, I get R1= 75k and R2=18k. The stability factor then becomes a much better 15!
Have I got this right?
I have one other question about the circuit. The parts circled in green (controls the multiplier frequency) and blue (low pass filter) are both related to frequency. Does this mean they are essentially voltage independent? - can i leave their values as they are even though i am using 9V instead of 6V? and if not, what do I need to work out. I afraid my understanding of the TCA440 is abstract at best, and i cannot fathom the datasheet.
BC550C transistor
TCA440 am reciever
marked circuit
where the circuit came from by Bertrik Sikken
BC550C transistor
TCA440 am reciever
marked circuit
