Nick Lawrence
Can this panel be downloaded with standard Compass software?
Can it be reprogrammed at the keypad?
Jim Rojas said:No, that is a Monitronics version. I don't think you can even monitor it.
If you have an bad board laying around, try swapping the firmware. You may
also need to replace the keypad as well.
Jim Rojas
Crash Gordon said:So the proprietary info is in the chip?...how about on ADT stuff..same
thing?
(I have a couple I can't use compass on- it'd be nice to be able to swap
the chip rather than the entire board)
Jim Rojas said:No, that is a Monitronics version. I don't think you can even monitor it. If
you have an bad board laying around, try swapping the firmware. You may also
Jim Rojas
Anytime you swap the firmware on the Ademco, you should always default the
panel with * 97, so it can load up the default settings on the eprom.
Jim Rojas
Crash Gordon said:Hey, you want this ITI Monitronics paperweightI have here?...or should I
deep six it?
So that's what I have been dooing wrong... I thought that just by
seating the chip with a hammer it would force the defaults in.
Terry
Jim Rojas said:Anytime you swap the firmware on the Ademco, you should always default the
Jim Rojas
