samiam
for a while now I have been doing double sided layouts and single sided
boards - with the component traces tracked with jumper wire.
I am now trying to do a TRUE double sided board and I wondered how you
folks handled vias?
I am thinking I should follow the same approach except that I would run
the wire through the hold and simply solder both ends?. Actually I bend
the wire and solder it to the trace at both ends.
Messy but it seems to hold for now.
Vias for signal traces are about 16mil in diameter. I drill the hole
with a 17.7mil drill bit. I am thinking I should look for "thicker"
jumper wire (instead of the 26awg) to stuff through the hole such that
it holds and I can snip off both ends and solder it cleanly without
having the bend it unto the trace
Any of my gibberish making sense? Maybe Ill post a link to a picture later
folks handled vias?
