VHDL Question: 'because it does not hold its value outside the clockedge'
Matt
Hello,
I am toying around with some GLUE logic to interface a 1655 to an
ISA bus. I have added my code below, however, when I try to synthesis
the code I recieve the following error:
"IRQ[0]" at isagluesimp,vhd (55) because is does not hold its value
outside the clock edge
I recieve that for all the IRQ lines in the IRQ vector. This error
goes away when I comment out the:
ELSIF (BCLK'EVENT AND BCLK='1' AND AEN='0' AND SA=address1 AND FLAG=
'0') THEN
line. ( I surrounded it in stars so it is more readable.
LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.std_logic_arith.all;
ENTITY gluesimp IS
PORT( SA: IN STD_LOGIC_VECTOR (19 downto
0); --system address lines
D: INOUT STD_LOGIC_VECTOR (7 downto 0); --data bus
IRQ: OUT STD_LOGIC_VECTOR (10 downto 0); --IRQ
vector. Only one pin is used depending on the IRQ selected
IO16: OUT STD_LOGIC; --when
addressed, IO16# is asserted
RSET: IN STD_LOGIC; --when
asserted, system has reset, all values return to initial state
IOR: IN STD_LOGIC; --when
asserted, the system is doing an IO Read
IOW: IN STD_LOGIC; --when
asserted, the system is doing an IO Write
BCLK: IN STD_LOGIC; --bus clock
from CPU board (8.33MHz) used as clk signal
AEN: IN STD_LOGIC; --when
asserted, address is invalid (DMA read in progress)
----------UART SIGNALS--------------------------------------
ADD: OUT STD_LOGIC_VECTOR (2 downto 0); --A2, A1, A0
used to select internal register of 1655
CHIPSEL: OUT STD_LOGIC; --CSA, CSB, CSC,
CSD chipselect for 4 different channels (ACTIVE LOW)
DATA: INOUT STD_LOGIC_VECTOR (7 downto 0); --Data register
for both input and output to/from card
ISR: IN STD_LOGIC; --Interrupts
from the 4 channels. These will be anded together
RD: OUT STD_LOGIC; --Read strobe
WR: OUT STD_LOGIC; --Write strobe
RESET: OUT STD_LOGIC); --Reset
--INTN: OUT STD_LOGIC; --Configurable
depending on the type of interrupts used (MAY NOT BE USED)
--TXRDY: IN STD_LOGIC; --If TX FIFO
buffer is full, this will be set (ACTIVE LOW, MAY NOT BE USED)
--RXRDY: IN STD_LOGIC); --If RX FIFO
END gluesimp;
ARCHITECTURE behavior OF gluesimp IS
CONSTANT address1: STD_LOGIC_VECTOR (19 downto 0) := X"002E8";
--declare base address vector for channel
CONSTANT interrupt: STD_LOGIC_VECTOR (10 downto 0) := "00000000001";
--declare interupt vector
SIGNAL FLAG: STD_LOGIC; --used to
inform the internal system an interrupt has been thrown
SIGNAL TRUEADDRESS: STD_LOGIC_VECTOR (11 downto 0); --contains
the usable address
SIGNAL TRUEDATA: STD_LOGIC_VECTOR (7 downto 0); --contains
the usable data
SIGNAL TEMP: STD_LOGIC_VECTOR (2 downto 0); --address
sent to the UART
BEGIN
PROCESS (BCLK, RSET, ISR)
BEGIN
FLAG <= ISR;
IF (RSET='1') THEN --RESET LOGIC
ADD <= "000";
CHIPSEL <= '0';
RESET <= '1';
RD <= '1';
WR <= '1';
IO16 <= 'Z';
D <= "ZZZZZZZZ";
IRQ <= "ZZZZZZZZZZZ";
FLAG= '0') THEN --I/O request from system
IO16 <= '0'; --inform the system that this
is an 8-bit board
TEMP <= SA(2 downto 0); --takes the base address away
for easier use
TRUEDATA <= DATA;
CHIPSEL <= '1'; --selects a
port
IF (IOR = '1') THEN --It is a read
RD <= '1'; --tells UART that it is a read
command
ADD<= TEMP; --sends register address to UART
D <= TRUEDATA; --data from the UART is
placed on the ISA data bus
ELSIF (IOW = '1') THEN
WR <= '1'; --tells UART that it is a write
command
ADD <= TEMP; --sends register address to UART
DATA<= D; --data from the ISA BUS is sent
to the UART
END IF;
D <= "ZZZZZZZZ"; --silence on the bus
IO16 <= 'Z';
ELSIF (FLAG = '1') THEN
IRQ <= interrupt;
IO16 <= '0'; --inform the system that this is
an 8-bit board
for easier use
port
command
D <= DATA; --data from the UART is placed
on the ISA data bus
command
to the UART
END IF;
IO16 <= 'Z';
END IF;
END PROCESS;
END behavior;
I thought this error occured if I tried to have another IF statment
using the NOT of a condition used in a previous NOT, but all my other
IF statements do not use the conditions of the line of code I
highlighted.
Any help would be great.
Allan Herriman
Hello,
'0') THEN
LIBRARY ieee;
ENTITY gluesimp IS
END gluesimp;
the usable address
the usable data
sent to the UART
BEGIN
BEGIN
FLAG <= ISR;
ADD <= "000";
CHIPSEL <= '0';
RESET <= '1';
RD <= '1';
WR <= '1';
IO16 <= 'Z';
D <= "ZZZZZZZZ";
is an 8-bit board
for easier use
TRUEDATA <= DATA;
port
command
command
to the UART
END IF;
IO16 <= 'Z';
IRQ <= interrupt;
an 8-bit board
for easier use
port
command
on the ISA data bus
command
to the UART
END IF;
IO16 <= 'Z';
END IF;
END PROCESS;
END behavior;
highlighted.
Some comments:
You really should follow the synthesisable code templates that the
synthesiser vendor provided in the documentation.
2. This is the sensitivity list:
The flip flop template has a sensitivity list which contains the
clock, the async reset (or set) input and nothing else. Remove ISR
from the sensitivity list of this process, and make the assignment
FLAG <= ISR;
on a line of its own outside the process.
3. Your flip flop model seems confused. Here's my cut-down version
of your code:
PROCESS (BCLK, RSET)
BEGIN
IF (RSET='1') THEN
FLAG= '0') THEN
-- Make no assignment to IRQ here
IRQ <= interrupt;
END IF;
END PROCESS;
Perhaps you meant to have the line
IRQ <= interrupt;
where I put the comment
4. Are you aware that the part after
will behave differently in synthesis and simulation?
The simulator will execute it on the falling edge of the clock if FLAG
is '1', and the synthesiser will produce an error message. Did you
really mean to code for a falling edge flip flop? (It does this
because BCLK is in the sensitivity list, and the only way to get to
that code is if there is an event (i.e. an edge) on BCLK that isn't a
rising edge, and FLAG is '1'.)
I'm guessing (without trying to understand your application at all)
that it should look something like this:
BEGIN
IF RSET='1' THEN
ELSIF rising_edge(BCLK) THEN
if AEN='0' AND SA=address1 AND FLAG= '0' THEN
IRQ <= interrupt;
ELSIF FLAG = '1' THEN
else
-- make no change to IRQ
END IF;
END IF;
END PROCESS;
At least it will be synthesisable.
5. Finally, this is off-topic for s.e.d. Please try comp.lang.vhdl
next time.
Regards,
Allan
F
Frank Buss
for easier use
port
command
Allan has already given some useful hints. One more: Looks like you are
assuming that you can use the value of TEMP within the same clock cylce.
This is wrong. ADD becomes the TEMP value from the previous clock cycle.
Use variables, if you just want placeholders for signal slides.
Another good newsgroup for posting such questions is comp.arch.fpga.
Matt
Allan and Frank,
Thank you for the responses and sorry about posting in the wrong
group. I had to tweak my sensitivity list and many of the errors
disapeared. I contiuned to play with my loops and finally got the
whole thing working.
Thank you for your comments,
Matt
