VGA monitor alignment software?
O
Oppie
I remember back in Win95, there was a utility to calibrate a (CGA) CRT
monitor. Anybody know if there is something similar buried in XP? Haven't
found it yet.
Needed to adjust a VGA monitor that is embedded in a CNC milling machine.
Couldn't find any utilities that came with the CNC. As a work around, I
used my laptop's external monitor connector. Set the display to solid color
background (Red) and did the purity adjustments. The icons on my desktop
gave me enough edges to align on. Not the best but it worked.
Ultimately, found that one of the machine operators had used a magnet to
hold a print to the side of the steel console that houses the monitor and
controls. I ran a big home-brew degausser over the case and it all seemed to
be OK.
Oppie
Martin Riddle
Haven't found it yet.
machine. Couldn't find any utilities that came with the CNC. As a
work around, I used my laptop's external monitor connector. Set the
display to solid color background (Red) and did the purity
adjustments. The icons on my desktop gave me enough edges to align on.
to hold a print to the side of the steel console that houses the
monitor and controls. I ran a big home-brew degausser over the case
and it all seemed to be OK.
Oppie
You can try Quickgamma http://www.quickgamma.de/indexen.html , but I
don’t recall if you can adjust individual color LUT's.
Cheers
