Very small, very long life, 10 turn trimmer pot?
I'm looking for a very low-profile trimmer pot (since it has limits)
that will be used for a knob that will be used a lot.
An encoder would've been nice but they keep turning and they're also
hard to find in this size:
It needs to be 6mm or less body width, height not including shaft a
half inch or less, shaft diameter close to 1/8" or less.
resistance figures doesn't matter. just long life. all i can find is
200 cycle rotational life and that is ridiculously low.
Unless there's an encoder out there with limits on it in that size.
H
HiggsField
Trimpots have really really short mechanical lifetimes. You might want
to think about a conductive plastic pot, as used in audio.
Cheers,
Phil Hobbs
An encoder would have a virtual infinite lifetime The sensor for the
encoder would be fully serviceable. Much more precise capability.
G
Generalspecific
yes. i realized that trimpots are not the right thing to ask for but i
guess i asked simply because they can be very small. i thought to give
them a whirl since i gave up on encoders...i have found an encoder
from bourns, the 3375, but it is obsolete.
http://www.bourns.com/pdfs/3375_obsolete.pdf
which would work for what i'm looking for. is there any other models
out there just like this in terms of dimensions??
tocos makes a 7mm one, that is too large.
i'm not looking to use some part dealer service where they require you
to have a few hundred dollar minimum order. something that is readily
bought.
W
whit3rd
There's an outside-the-box possibility in trim capacitors.
Little glass tube trimcaps (just solder a shaft onto the plunger)
are available about the right size. There's just the small
problem of detecting the few-picofarads value change.
Old auto radios used a sliding slug in a coil for some
variable inductors; one can tune with a brass screw
poking into the bore of a small solenoid inductor.
In either case, you'll have to look for small phase shifts,
or measure an oscillator frequency.
mpm
from bourns, the 3375, but it is obsolete.http://www.bourns.com/pdfs/3375_obsolete.pdf
bought.- Hide quoted text -
- Show quoted text -
Is this obsolete just because of RoHS?
If so, there may be a lead-free replacement (with a different part#).
Also, this datasheet shows a continuous mechanical angle. Is that
what you want?
There are also digital pots out there (Maxim?). But they're expensive.
L
Leo Marx
what you want?
Trimpots and pots in general are becoming obsolete.
Maybe you should try a 21st century solution?
http://datasheets.maxim-ic.com/en/ds/MAX5160-MAX5161.pdf
http://www.edn.com/contents/images/6541378.pdf
http://www.eetasia.com/ART_8800476279_499501_NP_540c4669.HTM
http://en.wikipedia.org/wiki/Digipot
JAM
