Jon Slaughter
Do they make very small mechanical relays(for switching very small currents
and voltages) that also latch?
Essentially I need a way to switch analog audio signals using a
"non-envasive" method... which means no semi-conductors(theres a reason but
don't bother asking... just assume its impossible and don't try to give
reasons why it should matter cause I already know them).
Obviously the coil is the issue but since the currents and voltages are very
low I assume that the conductor for the switch can be small also and
therefore one doesn't need such a large coil... or maybe theres some other
mechanism for switching that could be used...
What I want is for the switch to latch in the on or off state and need any
power to hold that state. I believe this could be accomplished with springs
or some other method of producing just enough friction to hold the switch in
place.
Any ideas?
Thanks,
Jon
place.
Any ideas?
Thanks,
Jon
