Ok, you electronics dorks should know the answer to this one. I work out of my car so I use a power inverter that I have wired directly to the battery under the hood. It is a deep cycle 12 volt battery. When the power inverter is on and I start the car, the inverter will often blink out and go from green to red, not supplying power to my stuff. I have to turn it off and then back on to get it running. It doesn't happen all of the time. I'm assuming the engine is drawing a huge amount of power and it robs it from the inverter momentarily, shutting it off. There's got to be a device (capacitor?) that I can wire between the inverter and battery that will prevent this from happening. Thanks for your help.
Brad
Brad
