Very Simple Electronics Question
I am making a circuit which will run of a 9V. All l do is connect the 9V battery to the loud speaker and it plays a siren noise.
Considering that l may only use this very infrequently and that the battery is ALWAYS connected to the terminals, l just wanted to know in your opinion which of the circuits A or B would be best and optimum for battery power conservation. I should not think that there would be any difference but just wanted to check with you.
Thank you
Circuit A is the most practical as it saves on a second switch.
Current cannot flow through the circuit until the circuit is completed by pressing the switch. Disconnecting the second terminal of the battery will do nothing to help conserve power.
Thanks, it only occurred to me as sometimes you put brand new batteries in a device, not use it and leave it for a month and then you find the batteries are completely dead/drained. hence, my original question. Thanks for the responses.
What makes you think connecting a 9V battery to a speaker will make a siren noise?
Bob
It is a device that has a circuit built in the speaker which produces the two alternating frequency tones. That was the only symbol l could find without drawing whole schematic out.
