Verilog 2's Complement Shifter
Davy
Hi all,
I am new to Verilog and want to build a 2's Complement Shifter.
I found
%displayb(8'b0001_1000>>2); //Output 0000_0110
%displayb(8'b1001_1000>>2); //Output 0010_0110
So >> is unsigned shift.
How can I build a signed (2's Complement) shift based on >>?
i.e. I want 8'b1001_1000>>2 //Output 1110_0110
Any suggestions will be appreciated!
Best regards,
Davy
Spehro Pefhany
Hi all,
I found
Best regards,
Davy
Verilog 2001 has >>> (signed shift operator)
Best regards,
Spehro Pefhany
Alan Nishioka
How about
12'b1111_1001_1000>>2
or
{ 32{b[7]}, b } >> 2
But note that the so-called "signed shift" only gives you a signed or
arithmetic shift if it is used in a signed expression. In an unsigned
expression, you get an unsigned or logical shift. It isn't really a
"signed shift". It is a "shift using the signedness of the
expression". It is what the ordinary shift operator should have been
in the first place.
