So I started to work on this project kit and after soldering three resistors I didn't like the amount of solder on the connectors so I switched to a thinner solder. That worked much better. I decided to remove the there resistors and use the different. I tried to remove the resistors using my brand new reflow workstation hot air gun, I figured this would melt the solder and I would be able to pull the resistors up with tweezers. It didn't work out as planned. All of a sudden I smelled plastic burning and I heard some popping/sizzling. The resistor was super hot and the board was bubbled.
What is the best way to test this? I was thinking of removing the resistors by my soldering iron this time and check the resistance with a multimeter. Is there a way to check the board? Could the excessive heat damage the board? The kit was cheap so I can always buy a new one, I'm just glad it was a cheap one and not one of the expensive ones.
I can upload pictures if needed.
