Hi
I installed a pair of Velleman ignition amplifiers in my 1970s Peugeot. These kits work by using the existing points (contact breakers) to fire a TIP 162 transistor. The transistor then earths the coil instead of the points. This reduces the load on the points from several amps to a few milliamps and so reduces points wear and increases reliability.
The circuit diagram is here
although mine don't have the 680R and LED.
The circuits are working well and the engine runs well, however in order to have a stealth installation, and to keep the circuits away from engine heat I ran wires inside the passenger compartment and put the circuits in a box underneath the dashboard.
The problem is that the circuits are making an annoying ticking noise which sounds like a couple of cicadas in the car. Both circuits do it (my car needs two because it has two breakers and two coils) so I don't think it's a component or assembly fault.
What could cause a circuit board with no moving parts to make an audible noise? what can I do to stop it?
