Hi all, for the life of me i can't figure out what mistake i've made putting together a MFOS VCLFO. Usually when i get readings like this I've done somert rediculous, but i can't seem to find my obvious mistake and was hoping you guys could help please? I include meter readings of transistors and IC's. plus off each pot leg. One stick point is that on the schematic MFOS says C11 should be "C11 (main oscillator integrator cap) should be a temperature stable type of cap (polystyrene, polycarbonate, etc.).
All others can be ceramic or film." however the soundtronics kit uses a ceramic cap here.
Here are the readings, I'll add below circuit shots and schematic. All readings are taken with pots turned full clockwise.
Voltage source is 12v
2N3904
Q1; E = 8.46/ B = 8.93/ C = 8.53
Q2; E = 8.46/ B = 8.8/ C = 8.4
Q6; E = 11/ B = 11 / C = 12
2N3906
Q3; E = 8.85/ B = 8.40/ C no reading
MPF102
Q4; D = 10/ S = 6.7/ G = 1.3
Q5; D = 11/ S = 11/ G = 11
TL082
U2; 1 = 11. 2 = 9. 3 = 8. 4 = -. 5 = 9. 6 = 6.3. 7 = 11. 8 = 12.
U4; 1 = 1.3 2 = 9. 3 = 8. 4 = - 5 = 9. 6 = 6.3. 7 = 11. 8 = 12
U5; 1 = 8.6 2 = 9. 3 = 8. 4= -. 5 = 9. 6 = 8.4. 7 = 9. 8 = 12
U6; 1 = 11. 2 = 7.5. 3 = 8.6. 4 = - 5 = 9 6 = 9. 7 = 8. 8=12
LM13700N.
U3; 1 = no reading. 2 = 2. 3 = 9. 4 = 9. 5 = 1.5. 6 = -. 7 = 300mv (rises up to here from around 20mv). 8 = 0.4v.
9 = 9.4. 10 = 11. 11 = 12. 12 = 11. 13 = 9. 14 = 9. 15 = 2. 16 = 1.1
LF442CN
U1; 1 = 9. 2 = 9. 3 = 9. 4 = -. 5 = 9. 6 = 9. 7 = 9. 8 = 12
Fine Potentiometer.
1 = -12. 2 = 12. 3 = 12
Course Potentiometer.
1 = no reading. 2 = 9. 3 = 12
PWM Potentiometer.
1 = 4. 2 = 7.4. 3 = 8
2N3904
2N3906
MPF102
TL082
LM13700N.
LF442CN
Fine Potentiometer.
PWM Potentiometer.
