Hey guys,
So I've got an ultrasonic system with a driver board and transducer. I would like to be able to vary the output frequency, as I've developed a horn that resonates at 26 kHz and not the 28 kHz the board outputs.
The circuit looks something like this:
https://cdn.hackaday.io/images/7856741430093121127.png
Not my drawing. But I think its fairly close, though I think that Q1 or Q2 is upside down. From what I can tell that is a Royer oscillator and one of those transistors should be opposite the other. Now I think that L1-1 is responsible for triggering Q1 & Q2. I think if I replace the signal from L1-1 with an Arduino I might be able to vary the output frequency. However this is what I refer to as "murder voltage" as its at times upwards of 300 V. I have the board connected to a switch that I can use to quickly turn it on and off. I don't take HV lightly but I think I'll be okay. Only one hand at a time!
My final question, I would like to attach my oscilloscope probe to L1-1, but I'm not sure where to put my ground connector. Any ideas?
