VARO R347/s Diode #7739 IN ANY PUBLICATION!!!!! PLEASE.
  • Thread starter Hubert Earl Rodenbaugh Jr
  • Start date
H
From: "Hubert Earl Rodenbaugh Jr" <[email protected]>
Subject: Specs for a VARO R347/s Diode #7739 for Onan AC Generator
Date: Sunday, September 26, 2004 12:20 AM
I need specs for this diode if anyone has it in a publication. The generator
is Running but will not generate voltage. The triple diode cluster has a
bolt on base and is apparently a heavyweight. The generator is an older
three ring brush type of about 5kw. There are three connectors on the top at
45 degree angles and a fourth slot but it is empty. I cant even find the
first hit onthe internet for the manufacturer! I went to the Unusual Diode
website http://www.avtechpulse.com/faq.html/III/#links-manu but they didnt
have any links to this part that I could find. HELP please if you can give
me any measures or values I would greatly appreciate it...Thanks.
CFoley1064
Subject: VARO R347/s Diode #7739 IN ANY PUBLICATION!!!!! PLEASE.
From: "Hubert Earl Rodenbaugh Jr" [email protected]
Date: 10/3/2004 10:46 PM Central Daylight Time
Message-id: <[email protected]>
I no longer have my old 1980 Varo Semiconductor catalog. I'm sure it would be
in there.
Varo was bought out a number of years ago by Micro Quality Semiconductor, and
is now called MicroSemiconductor. I had an issue several years back with a
spec on an old Varo part, and the apps people at Micro Quality were able to fax
me out a data sheet. As far as I know, they still make hi-rel diodes, mostly
for mil applications. Give their engineering department a call, and you might
get a favorable response.
http://www.microsemi.com/
Good luck
Chris
