Hi
I need to connect two parts of a project with 12 lines, most carring analog signals (e.g. piezo bender, valve, touch detector etc). USB-C seems like an elegant compact cable to do that with the right breakout. However its not clear to me if the wires will work unless I power the cable up and run some protocols.
Is that a direction worth checking or should I give up.
m
m
