Andrew Rich
Why the heck did u ask such a dumb ask question ?
Thanks for everyones help, RSSI was mentioned to me by a fellow
academic and I'm at the stage of researching its possiblilites.
He seems to think that it is possible.
I will keep looking into it as I also have a backup plan using the
webcam.
Having done some more research today it looks like other posibilities
include acoustic positioning or infrared positioning (e.g.http://instruct1.cit.cornell.edu/courses/ee476/FinalProjects/s2004/rd...)
What does everyone think about the other technologies mentioned above?
You are wasting your time, visual object recognition is the best
method in this particular instance. All the other methods (RSSI,
acoustic, and IR) require a transmitter on the boat and multiple
receivers. Visual recognition on the other hand doesn't require any
transmitter, will work with almost any size or type of object, is
simple, fairly accurate, will most likely only require one receiver,
and reduces the problem to essentially a software solution.
The decision is blindingly obvious.
Dave.- Hide quoted text -
- Show quoted text -
Josh916 said:Thanks for everyones help, especially David Jones, I will be going
with the visual recognition. It was originally my first choice though,
as you do, I wanted to exhaust all possible options before finalising
the decision as you never know there might of been an easier, more
efficient way.
Josh
I would like to use RSSI to locate an object in a 3D space. The space will
be a square box with transmitters located on the 4 corners. An object will
be place at certain positions within the box and I want to be able to
determine its location inside the box. Much like an internal GPS.
received signal strength indicatorWhat's "RSSI"? Repetitive Stress Syndrome Imaging? ;-)
Thanks,
Rich
I think if he can equip the box with a wire grid and have a receiver on theRich Grise said:Oh, gosh. Than that's definitely a non-starter. I'd at least try
ultrasonics, or maybe lidar and triangulate. But, as has been said,
just imaging from the top is probably the best, since compute power
is cheap these days, and Josh916 seems to have total control over the
environment.
Of course, if you're out on the lake, it'd probably be pretty expensive
to hire a blimp for the camera. ;-)
Thanks!
Rich
Josh916 said:I would like to use RSSI to locate an object in a 3D space. The space
will be a square box with transmitters located on the 4 corners. An
object will be place at certain positions within the box and I want to
be able to determine its location inside the box. Much like an
internal GPS.
I would like to know what components (IC's?) I need to perform such a
task.
Or if anyone else has any other more effective methods to acheive such
a task your comments are welcomed.
Thanks,
Josh
efficient way.
Josh
