Hello,
I need to get 3.3v from a 5v input to power an FPGA. Since I'm already
using bus switches to convert the input lines from 5v to 3.3v, I was
thinking about doing to same for VCC and not using a voltage regulator
in the design. These are the parts I use:
http://www.idt.com/?genID=QS3125
According to the datasheet, the bus switch can put out 120mA max. My
FPGA is a LatticeXP LFXP3 which uses 90mA max on startup:
http://www.latticesemi.com/lit/docs/datasheets/fpga/xp_data_sheet.pdf
It seems that I could use these bus switches as voltage regulators if I
wanted to. Is it a good idea though?
