I just got back. Thanks for the feedback.
The application isn't really classified in the sense that I'm not planning
on putting LEDs into a stronglink or anything but there are some geometrical
constraints which will mostly impact the coil. Any standard LED will fit
into the space I have. The intent is to have the LED flash briefly but
intensely. The coil needs to fit in a fairly narrow space so it needs to be
"flat" (as in probably occupying less than 1/4 inch thickness) . The coil
can be long. Let's say we had a long thin coil with lots of windings.
If there is a long slender coil (say 4 inches long wrapped around an 1/8"
diameter mandrel) with the proper number of turns, does the influence of the
magnet (which is let's say 1/4" diameter x 1/10" thick) become
time-dependent? Will the induced current gradually build up as this magnet
traverses along the coil? Are additional components needed in this case?
Remember, I am looking for a briefly flashing LED -- no constant output
required.
Also, I am messing around with various coils, chokes and wal-warts. Some of
these devices seem to have a metal mandrel, some don't. How do I know what
kind of mandrel (core) to use?
Regards,
Mike
Paul Hovnanian P.E. said:
John_H said:
[snip]
Take the guts out of this:
http://www.sharperimage.com/us/en/catalog/productdetails/sku__DK013ZZZ
and you have what you need. Moving magnet, coil, LED, let there be -
shake shake shake - light!
Don't forget the bridge rectifier and the supercap.
Paul Hovnanian mailto
[email protected]
Disclaimer - These opiini^H^H damn! ^H^H ^Q ^[ .... :w :q :wq :wq! ^d
exit X Q ^C ^? :quitbye CtrlAltDel ~~q :~q logout save/quit :!QUIT
^[zz ^[ZZZZZZ ^H man vi ^@ ^L ^[c ^# ^E ^X ^I ^T ? help helpquit ^D
man quit ^C ^c ?Quit ?q CtrlShftDel "Hey, what does this button d..."
