Hi Harald!
I'm sorry for dont respond before. You moved the post (With all the reason) and I didn't recive the mail notifying the response on the post.
You are right, I had an error of concept. Thanks you very much for clarify me this.
I have a Combro Cb625(Chronograph for airgun shooting, my other hobby), and it let you buy or make a interface to connect the combro to the computer.
I would like to make becouse in my country nobody sells it.
The manufacturer gives you the circuit to connect the combro, but it works with DB9 serial port. So, the idea is to make a USB interface and not to use serial ports:
With these properties:
"The serial output. The little three pin connector near the clamp bolt allows you to connect your cb-625 directly to a computer. See elsewhere on this web-site for details of the interface to buy or here for the details to build one. In brief the output is 9600 baud, 8 bit ASCII, no parity, one stop bit as 0-5 volts that needs inverting and converting to the RS232 for the computer. The output is an ASCII text number followed by representing the number of 4MHz counts to cover the 2.353 inch gap so "1000" represents 784ft/sec. There is free software available on this site for Windows systems to collect and display this data."
Googling I found a post here, similar to my request:
https://www.electronicspoint.com/threads/usb-to-serial-question.266832/
But the owner of the post bought this cable:
http://www.amazon.co.uk/gp/product/B00F2F5HVK/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
I cant buy that, the only thing I could buy was:
http://articulo.mercadolibre.com.ar...uart-ttl-cp2101-programa-arduino-pro-mini-_JM
(I attached more pics of the USB, and the configuration on the PC)
I also used the circuit that the user "gorgon" recomended to Peter, instead of the original.:
Yesterday, I recived the Usb to UART converter, and I made the circuit...But it didnt work.
Could you help me?
Can this usb converter be usefull?
Thanks you very much!!! And sorry for my bad English.
Regards.
