Connecting a sensor directly to a PC is the most cost-effective method
for high-precision power measurements, especially if a PC is already
used for data acquisition and evaluation. Moving the control and
measurement display away from the sensor and into the PC means you
save space and reduce cost.
We now are able to make our product even smaller with the use of a
PDA. This gives the ability to have the measurements that you require
to take "In your pocket".
There are three frequency ranges:
12.4 GHz, 18.5GHz and 26.5 GHz
Purchase the following online at:
ST124SMA 12.4GHz
http://www.satori-technology.com/products_st124sma.htm
ST185SMA 18.5GHz
http://www.satori-technology.com/products_st185sma.htm
ST265SMA 26.5GHz
http://www.satori-technology.com/products_st265sma.htm
The power sensor is only 1.7 x 1.350 x 5.2 inches (34x 43 x 132 mm)
and can easily be operated from a laptop. Cables and software are
provided as standard.
PDA interface “Power Meter in your pocket”
http://www.satori-technology.com/products_ST1.htm
Power Meters make connections via USB
http://www.satori-technology.com/documents/PowerMetersViaUSB.pdf
See the “Power Sensors Work With USB Computers” article by Jack Browne
in Microwaves & RF at the following URL:
http://mwrf.com/Articles/Index.cfm?Ad=1&ArticleID=14045
See data sheets and specs:
http://www.satori-technology.com/products_st185sma.htm#specifications
For information contact:
[email protected]
Tel: +44 (0) 1899 229258
ST124SMA 12.4GHz
ST185SMA 18.5GHz
ST265SMA 26.5GHz
[email protected]
