ArameFarpado
hi all
i have a situation with USB ports that drop down the 5volt power in pins
1 & 4, when this appens, all devices connected shuts down.
(funcking VIA controllers)
i was hopping to solve this without spending more money (this is a bad luck
computer that allready had to replace a lot of components and belongs to a
family with low resources). I've read about one possible solution that goes
by installing a "self-powered USB-HUB" but it costs ¤ and i'm not sure that
will solve the problem.
so... i was thinking about desconect the 5 volts pins on the usb port (those
that come from the controller) and connect 5volt directly from the main
power unit, but i don't know if this is a good idea... will the controller
still recognize devices attached and put then to work? or the controller
needs to detect some mA on the power lines to detect devices?
Does anybody allready tried this?
Advices please.
Many thanks
ArameFarpado
Advices please.
Many thanks
ArameFarpado
