urgent help needed in 8051 project
G
gagan
my Project based on 8051 microcontoller
i have to sense temperature then store the result in pc & dispLAY it on
7-seg.
first sensor will sense temp then
adc(0804) will convert it in dgital value and it display result 7-seg
and store it on pc it on .
so i have to interface adc ,7seg with 8051.
i have to develop assembly language code for it also
SO PLEASE HELP ME OUT
AND PROVIDE ABOVE INFORMATION.
martin griffith
7-seg.
How far have you got with your project?
Have you got a hardware /PCB design?
Interrupt driven or polled?
you could start here
http://www.intel.com/design/auto/mcs51/manuals/272383.htm
martin
pronforall
7-seg.
The 8051 is very popular ... you can probably find interfacing related
projects online.
I think www.8051.org ... if memory serves me right
DaveM
7-seg.
Sorry... I don't do homework any more... Been there, done that.
Dave M
MasonDG44 at comcast dot net (Just substitute the appropriate characters in the
address)
Never take a laxative and a sleeping pill at the same time!!
John B
gagan scrobe on the papyrus:
on 7-seg.
I DON'T DO HOMEWORK EITHER, BUT I CAN SHOUT JUST AS LOUD AS YOU!!!!
Jim Thompson
7-seg.
I'm always puzzled by requests to DO your homework for you.
With that kind of an attitude might I suggest another trade... PERHAPS
you are capable of flipping burgers ?:)
However I want every other student lurking here to know... if you show
that you exerted some considerable effort and are simply hung up or
confused on one or two points, feel free to post your query!
...Jim Thompson
G
gagan
to jim thompson u r simply a bloody basrered if u cant help a needy one
then shut up ur mouth
Michael A. Terrell
Illiterate trash.
PLONK.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
Michael
Don said:
Most people using 8051's need urgent help.
Use a PIC instead.
Yeah. What's up with all the 8051-related "emergencies"? One would think that
those schools have not heard that other uC's have come along. (Oh ... I think I
understand now: probably too much of the budget is spent on PC's, so not enough
left over to buy more convenient - and in certain cases more capable - uC's and
associated development tools.)
That said, a former colleague of mine with nearly 40 years in the mainframe and
PC server business still uses 8051 (w/ BASIC!!) for his projects. He used a
FLASH uC (Atmel) for the first time fairly recently (at work) and couldn't stop
commenting on how much faster development goes when you aren't constantly
loading the EPROM eraser.
7-seg.
Wire the ADC data and conversion start pins to the 8051.
Wire the 7 segment segment and digit select lines to the 8051.
Learn how to get data from the ADC.
Learn how to turn on segments of the displays and multiplex the digits
Build a lookup table to convert numbers to segments
Write a routine to convert ADC values to decimal numbers
At the end of your routine, jump back to the start.
etc
Spehro Pefhany
There are a lot of 8051 trainer boards floating around. I don't think
it makes much difference so long as you actually learn to use one
micro or another (and not just ripping off code from someone who has
actually absorbed the information and knows how to program). Except
perhaps the PIC, which, like BASIC, can actually cause the premature
death of otherwise potentially useful brain cells.
<LOL> Well, ARM is the 8051 of the current century.
Best regards,
Spehro Pefhany
John B
one then shut up ur mouth
A really good way to get help.
Rich Grise
<LOL> Well, ARM is the 8051 of the current century.[/QUOTE]
Well, I've actually _used_ an 8051, and I lament the loss of the Motorola
68HC series. I've been reading about PICs for a couple of years now, and
it looks like even more of a programming nightmare than the 8051. =:-O
Thanks,
Rich
Spehro Pefhany
68HC series.
Sure you didn't just misplace it?
Thanks,
Richh.
The newer higher-end ones are not as horrible as the older ones.
Best regards,
Spehro Pefhany
