Update to AoE's "selects MOSFETs" table?
Joel Kolstad
Anyone care to suggest their favorite readily available & sanely priced
MOSFET? I'm looking at AoE's table on page 126, and some of the ones they
suggest such as the 2N4351 don't seem too horribly available anymore. (I am
after those designed to be used in their linear region, not just "digital
FETs" that are aimed mainly at switching applications.)
---Joel
W
Winfield Hill
Joel Kolstad wrote...
priced MOSFET? I'm looking at AoE's table on page 126, and some
of the ones they suggest such as the 2N4351 don't seem too
That's still available, although it's more affordable
and readily stocked if the die is in a plastic package.
(I am after those designed to be used in their linear region,
not just "digital FETs" that are aimed mainly at switching
applications.)
What are you tying to do? The 2n4351 was a rather wimpy
yet expensive part and isn't so popular anymore. Small
discrete enhancement-mode MOSFETs like the sd210 may
be better suited, depending on what you're trying to do.
And "digital" parts like the 2n7000 can be used in the
"subthreshold" linear region just fine, of course, but
you may find they have too much capacitance, depending
on what you're trying to do...
Joerg
Hello Joel,
Oldie but goldie: How about the BF998? Dual gate MOSFET. You get a real
hot rod for around 10c in large qties. At least one of these should be
listed in the new AoE since there is a surprising number of engineers
who don't know anything about transistors used in TV sets. Heck, I have
met some who didn't know that dual gates existed.
In the more modest frequency ranges I have done lots of linear stuff
with the old BSS123. Around 5c. It's similar to the 2N7002, higher Rdson
(which you probably don't care about here) but also higher voltage.
Joel Kolstad
Hi Win,
Primarily mess around with building some discrete amplifiers, current sources,
and "linear resistors"... initially so slow anything would work, and
eventually up to some mid-tens of MHz. Pretty low power levels -- generally
not more than a watt.
Essentially I was after the 2N3055, 2N3904 & 2N3906 of MOSFETs... and JFETs,
for that matter.
Thanks for you help,
---Joel
