Unknown SOT23 - need help identifying
Hi
I have a fault on a car part and expensive repair. the fault is the following part.
I have spend a long time trying to find this part T1s
please see attached picture
Please can anyone tell me a part number?
Jason
Thanks for your reply
I have just fitted BC17 (rs part number 807-5122) marking T1
This did not work.
In the past few weeks I have also tried
MMBT2369ALT1G Bipolar (BJT) Single Transistor, NPN (farnell part 1653624RL)
MMBT2369A Bipolar (BJT) Single Transistor, NPN (farnell part 9846719) marking 1S
BZX84B7v5 (rs part 800-9771) marking T15
BC807 -25LT3g (rs number 690 0079)
Thanks for your help do you have any other suggestions? I really need to get this part working.
Jason
Have you got a wider view of the board where its mounted? Preferably with details of the tracks interconnecting to other components?
If it is a simple transistor then practically anything of the right polarity would work, including thru-hole parts soldered to the board pads - just to get the thing working.
Using parts other tha the exact replacement usually results in the pinout being different.......
Ther could also be another fault and/or the fault you have identified may be wrong - we don't know....
davenn
This did not work.
Jason
well that suggests, as @kellys_eye said, that there may be other problems with the board … the part itself doesn't look like it has failed
Those meter readings suggest that the device is internally shorted, if it's out of circuit; or else give no useful indication of device properties if it's in circuit in parallel with low impedances.
Hi guys, I had a suggestion from another member, R3130N44HA
I have been busy finding R3130N44HA and its not that easy! I have found ONE data sheet that says a T1 marking with "s" being place of manufacture. so i tried to find it.
There are 4 types of R3130N part, all very slightly different. but all do almost the same function.
The only part I could get my hands on was R3130N22EA and this sadly did not work. I have tried to purchasing from china, eBay allibarber the 44HA type with no joy. Fitting this the automotive part did not work, refitting the 2 original T1s sot's onto the unit work again.
Note Pin 1 is connected directly to 0V/Ground on the board
Any other help would be appreciated
Regards Jason
Ok
What do I know. Its a 5v board, pin 1 is to 0v/gnd & Pin3 is NOT CONNECTED
Pin 2 goes direct to pin 77 if an infineon IC C164CI
Port 5 is an 8-bit input-only port with Schmitt-Trigger charact.
The pins of Port 5 also serve as analog input channels for the
A/D converter, or they serve as timer inputs
Any ideas?
Regards jason
http://www.rebuild.org.uk/site-images/pin77.JPG
D converter, or they serve as timer inputs  Any ideas
Ok
Any ideas?
Regards jason
Just wondering if you manged to find out what part this is?
Did you manage to fix your throttle actuator?
