G
Guy Macon
Pooh said:I don't right now either. Always mucking about with the guts.
My PC will catch fire if I run it without the cover.
(Compaq 5500R with quad processors).
Pooh said:I've always assumed that US 'duct tape' is what we call
'Gaffer tape' here in the UK.
In the US, the term "Gaffer's Tape" refers only to real Gaffer's
Tape, never to Duct Tape, and the term is is used primarily in
the TV and film industry.
I've always assumed that US 'duct tape' is what we call 'Gaffer tape' here in
the UK.
Hard wearing stuff with an awesome adhesive and a PVC coating ?
The UK name originates from the use of an 'old gaffer' on most film sets to
'fix things up' - usually involving tape.
Guy said:In the US, the term "Gaffer's Tape" refers only to real Gaffer's
Duct Tape has a smooth, usually gray, plastic surface. Gaffer's
Tape has a cloth, usually black cloth surface. The adhesive used
on Gaffer's tape will not pull paint off of a wall or leave behind
any adhesive residue. Duct Tape will. There is a variation on
Gaffers tape with low temperature adhesive designed to seal film
cans which are stored under refrigeration.
I still remember my old days as a step by step telephony equipmentmartin said:I was So Glad when I got old enough not to hear the scream from
unsynced TV monitors in studios. But I was on the beach campsite a
couple of months ago and could hear a piezo igniter clicking 25m away,
cos the fridge had run out of butane. Thats the problem being an ex
sound maintainence engineer, you listen for the noise, and not the
music. Think its called "professional deformation"
martin
Robert said:Duct tape is a combination of a wide mesh of threads and a touggh
plastic foil. It comes in either silver or black with a shiny
surface, it's hard to get off stuff without glue residue, and it
stinks. Gaffer tape is more cloth-like, can easily be torn off if
you do it right, leaves no residue, comes in a variety of colors,
doesn't stink, and costs about four times as much as duct tape.
If a gaffer were using duct instead of gaffer tape it'd be his
last job with that particular DP.
John Larkin said:Zero. I pulled the noisy drives, swaddled them in bubble-wrap, and
jammed them back into the bays. Hard drives don't need cooling, do
they?
they?
John
Spehro said:That and "Reel Blood", which comes in several variations (old,
oxygenated, etc.)
Seems a touch pricey at $130 US/gallon, but probably few movies
outside of the slasher genre need that much fake blood. ;-)
