Hi there
I'm after some help with a project I'm working on at university. I'm designing heated handlebars. I'm using two wirewound 50w 10R resistors in each end of the handlebar to act as the heat source. I've found that around 15v/2amps is enough to generate a sufficient amount of heat in these resistors.
My next step is to work out how to connect these two resistors to an 11.1v lipo battery so the handlebars can be powered on the go, as opposed to using a power pack which I'm using currently. Unfortunately electronics is not my strong point so I'd be very grateful for some guidence.
I'd like to know what circuitry I'd need to build to safely supply power from my lipo to the resistors, and how I'd control the current so I can control how much heat the resistors give out.
Thanks for any help!
