Unexpected behavior of laser diode salvaged from DVD drive(s)
W
Wolfgang.Draxinger
my current pet project is a digital optical communications system. For
that, I was given a large bunch of old, identical DVD drives (non
broken) to salvage parts from. So took the DVD drives' laser diodes, of
course with ESD protection.
The first unusual thing I noticed was, that those laser diodes had four,
not the usual three connectors. So I spent some time figuring out (or
so I think) the pinout:
LD_Cathode LD_Anode PD_Anode PD_Cathode
In the end I had the laser diode shining, regulating up the current and
laser operation beginning at around 10mA -- directing it through an
etalon I could see the fringes, as soon as coherent radiation was
emitted.
Since I have a large number of those diodes I decided to sacrifice one
or two to measure their safe operation limits. So I began yanking up the
current, expecting COD or some other form of damage at some point. At
about 100mA it got dimmer, but to my surprise when I reduced the
current back to 10mA it was again emitting bright, coherent radiation
(passing through the etalon fringes well visible). So in "vain" I
yanked up the current up to 500mA, but still no damage on the laser
diode, which isn't what you'd expect.
Any ideas what is going on there?
Wolfgang
U
Uwe Bonnes
In de.sci.electronics Wolfgang.Draxinger said:
my current pet project is a digital optical communications system. For ....
Wenn die Dioden warm werden, dann geht die Lichtausbeute deutlich
zurueck. Kann das evt. nicht auch den Effekt bei 500 mA erklaeren?
W
Wolfgang.Draxinger
Vorher sollten die doch durch COD sterben und danach nur noch als LED
leuchten oder so, wenn überhaupt. Aber da war nach wie vor
Laseraktivität.
Wolfgang
W
Wolfgang Schmidt
Am 16.08.2011 19:00, schrieb Uwe Bonnes:
Die Lichtausbeute geht nur relativ zur elektrischen Leistung zurück.
Absolut sollte sie weiter steigen, bis zum Exitus.
Wolfgang
