I've recently been trying to get into electronics, but there is something I just cant get my head around, which are positive and negative charges.The questions I have are : whats the difference between them, why do we use both and not just one(i thought only electrons are useful) and are the positive charges all protons or what?
I know these questions are pretty stupid and I have probably wrote them in the wrong section , but I am really confused and any help in this area would be greatly appreciated.
An atom is the smallest unit of matter. Its constituents are electrons, protons, and neutrons. These three atomic particles are thought to consist of still other subatomic particles. The movement of electrons, protons, and neutrons cannot be thought of as abstract concepts, because they have both mass and, with the exception of neutrons, also charge. Electrons and protons are charge carriers, and have equal and opposite charges, which are named positive and negative. There are just as many positive charges in the universe as negative charges. Charge movement is called current. The
mathematical convention is to assume that charge is positive and moves from a positive to negative voltage. If you have to know the
real direction of the charge, then keep the same calculated direction if the charge carrier is positive, and reverse the direction if the charge carrier is negative.
Moving charges cause magnetic fields to form, and an accumulation of charges cause an electrostatic field to exist. A moving stream of neutrons will not cause a magnetic field, and an accumulation of neutrons will not form an electrostatic field. Electric charges also enable the transfer of energy along conductors. A stream of neutrons will not transfer any electrical energy and cannot be moved by voltage.
Ratch
