Can anyone tell me why I'm unable to read the frequency of a tone signal with my frequency meter? Equipment used in this question is a Victor VC3165 Frequency counter and a Instek GOS6112 oscilloscope.
Circuit being tested is an oscillator that is generating a 67 Hz tone, Note: The signal is a triangle sine wave and has been set to a very close 67 Hz using the oscilloscope.The output of that oscillator is going through a resistor to the base of a NPN buffer. The output of the NPN (emitter) then goes through a split resistor bias to ground, The signal at the junction of the split resistor is then outputted to an audio preamp circuit through a .01uf npo capacitor.
I can read the output from the oscillator, at the base of the NPN, at the emitter of the NPN and at the junction of the split resistor with the oscilloscope but can't read the frequency of the signal with my frequency counter anywhere in the circuit. I've tried to couple the freq meter with various values of resistors, various values of capacitors and even direct coupling, The display on my meter either freezes or radically displays random numbers. Note: I checked the freq meters function with a known Audio signal generator and is working ok.
Most likely left out some details, just ain't perfect these days. Got questions...please ask. Any help will be greatly appreciated.
