Unable to put the back the cover of my timex watch
My Timex watch fell to the floor and the back cover came out. I have
tried to put it back with a hammer covered with some clothes without
trying to put too much force on it to no avail. I think I am missing
either the right tool or the right technique. The cover doesn't have
screws. I'd appreciate any suggestion that might save me the trip to
the watchmaker.
jakdedert
the watchmaker.
It must be your technique. Even if the cover was slightly sprung by the
impact, it should be easily refitted. Nothing like a hammer, IME, is
ever required...simple finger pressure.
jak
Charles
the watchmaker.
I use a vise. I cover both sides of the watch with a heavy cloth (like
flannel) and carefully line things up and carefully close the jaws of the
vise. Has worked every time for me. In your case, the hammer might have
distorted the back and you might be out of luck.
Jerry G.
To put the cover back on by hand takes some skill, very strong hands,
and practice. Some people use a vice or a channel locks. I have seen
watches damaged doing that.
When putting back a watch cover, take care that some are keyed, and
only fit in a particular direction. If you have an alarm in the watch,
in some models the cover has to fit a specific way. In many of these
watches, there is a contact spring that sometimes pops out when the
cover is removed. make sure you did not loose this spring. If you did,
the alarm will no longer work.
The jeweler uses a watch case press fit tool for this purpose. They
have a set of dies for the different size watch case combinations. The
watch is fitted between the two dies, and then the tool presses down
to press fit the cover and the body of the watch back together.
Take the watch to a local jeweler if you cannot get the cover back on.
Most will do it for free. Some will charge a few dollars. While you
are doing this, it may pay to change the battery if it is more than a
year old.
Jerry Greenberg
Allodoxaphobia
tried to put it back with a hammer ........
"Takes a lickin' and keeps on tickin'."
John Cameron Swazey
Alas, those days are gone.
Jumpster Jiver
the watchmaker.
Around here - New Jersey, USA - any jeweler and some independent places
charge only about $5.00 for a new watch battery. If you can't get it
on, go to a place like this and they'll sell you a new battery and put
it together for you.
