Hi, i've been trying to fix this myself for a couple of days and have got stuck.
i was given a B&W Aura AUV-80LE-MIR amplifier which had its volume dial broke along with a pair of speakers.
i noticed the right channel only worked if the volume dial was messed with and the nut tightened or loosened. i tested the speakers and the wiring and that was all fine so it had to be dial.
i took the case apart and did some research and it seems that the dial is an alps potentiometer unfortunately the markings have smudged and i cant make out what it says. on the board where the unit is soldered it says VR201
i did some googling and i think i am after a 200 ohm dual gang potentiometer
the problem is i cant seem to find any parts matching this description. i can find 200 ohm single gang and a variety of dual gang but nothing identical
i have tried cleaning the dial but that finished it off and i cant get the right channel at all now
any help would be greatly appreciated
