I have a "Baxter" Ultrasonic cleaner Model ME11. I have seen elsewhere the guts for Metzler ultrasonic cleaners, and they are identical. I bought my cleaner on ebay and was using it to clean a motorcycle carb, and it quit half way thru. Investigation showed two 2A blown fuses which I replaced and they blew again instantly (incandescently) upon turning on the switch. The fuses appear to be on parallel circuitry for each of the two transducers, and I don't know that it was waoring on both when I got it, so the fact that 2 were blown does not mean the failure effected both sides in one event.
I cut off the transducers and tested no continuity in both directions with my analog multitester. Other than that, I test a bit of reverse continuity on one of the DII RL
225 diodes but not on the one in the parallel circuit, but I haven't isolated it so I don't know if the diode is at fault or something else.
I am attaching a photo of the circuitry and my drawing of it in the pdf below the photo (I recorded the shape, color, and markings of each component to avoid a mistake on my part in identification, but I do sort-of know what I am looking at and how it works). So far I have diagramed the part of the circuitry in the box on the photo.
View attachment CircuitDiagram.pdf
I hope to fix this and make it work again. I expect to complete the circuit diagram and then to begin un-soldering one end of each component for testing, but my testing is limited to my multimeter, so I don't know what to do with the transistor. I don't see any obvious burned parts (except the fuses).
Any wisdom would be greatly welcomed!
