Hi to all, Just joined the forum and would ask for some feedback please from anyone who may have noticed perhaps some similarities to these: I am using a ULN2803A controlled off the outputs of a MCP23017 I/O expander, this drives the ULN2803 input directly with a 3.3volt bias. I also have another circuit driving the ULN2007 chip from 5v 74HC logic chip. Both the ULN IC's have the same internal circuit but they are in two different boards - no connection to the other. Both the ULN devices sink coil current of a 24dc/80ma relay, 1 x relay per channel. On many occasions two adjacent channel relay coils are required to oscillate simultaneously. Over the period of a year and for several years now the 5v board freezes and now with the MCP23017 board only 12 months old it has demonstrated a similar occurrence, both very seldom mind you. Needless to say I have exhausted everything I can think of to identify the cause but seem to end up starring at this ULN relay driver chip. After sitting for many hours with a crow on the input of the 5v ULN2007 and adjusting to various time divisions I started to notice a 10 - 20 nanosecond blip appearing on the ULN input pin in excess of 40volts dc. Strewth!! Obviously this is coming from the relay coil's back EMF. - I do have the freewheeling diodes common pin of th eULN connected to relays 24vdc source.
I am beginning to form an opinion that the ULN 2803/2007 may have on certain situations of oscillating outputs of relays a latency of coil back emf suppression which is passing through the chip to the logic IC's before it and stalling them. I would like to know if any one has had a similar experience with this relay driver?
Cheers
Lindsey
Cheers
Lindsey
