I am trying to use the ULN2803A relay driver for the first time. I am following the set-up as here: http://computerchristmas.com/christmas/link-how_to/HowToId-17/Control_using_a_ULN2803A
I am waiting for acceptance to their forum but, hope to get an answer here faster.
I have connected all inputs with the resistors in series and have wired three resistors on three of the outputs with their other side of their coils to the positive supply (five volts in my case as I aim to use 5 volt dc relays.
When I measure the voltages across each coil in turn it is down from five volts to around 3.3 volts.
Is there a good reason for this? Perhaps I can't use 5 volts as a supply for the relays?
I have the 0 volts from the relay supply connected to pin 9 of the ULN2803A as well as the 0 volts from the TTL signals.
Thanks in advance or in fact if someone else has a schematic other than I have described above showing everything needed to drive 5 volt relays and the chip, I would be most grateful.
