K
Kim Sleep
A friend of mine has recently acquired a brand new Uher professional tape
deck. I have not had a chance to look at it, but according to him it has the
following problem:
(snip) I tried various cassettes from my library and they all seem about 20%
faster. So, I tried to record a A440 oscillator tone and used an electronic
tuner to watch what it was doing. It played back but the speed slightly was
changing throughout. I didn't measure voltage, just pitch.
Now, there is a yellow LED that says 'variable' which I'm assuming has
something to do with either servo or motor speed. When rewinding, the lamp
stays lit - but upon record or PB it was flickering at different rates. As I
have no manual, I'm not certain what the LED is for and the U.S. Uher fixer
wouldn't even answer my question. (His reply: "Send it in, we'll fix it".)
Wouldn't even tell me *what* the yellow LED indicates!!!! (Asshole!)
My suspicion is this was a European model and it's getting it's motor speed
from line voltage. Of course, the 50 HZ / 60 HZ make sense right? If it's a
import, regardless of the voltage - which I know is correct - would the
motor need to be changed if the unit was originally intended to be run at 50
hz? That's my question. Just give me your thoughts, a guess or a stab in the
dark. If you search Uher repairs - everything is in Kraut. The guy at SMC /
Nixontapes he calls himself - is the only guy I could find.(snip)
Anyone have any ideas?
And if it is truly a unit that requires 50hz, is there a power supply
conversion that can be done. I remember back in the 80s there were a ton of
kits that would allow 12volt clock kits to be used in cars, by supplying a
60 hz source into the dc supply.
following problem:
